9 years ago"For... Loop" simulates differently then discrete assignments?
Can someone help me understand why the first code snippet works as I would expect it, but the second snippet simulation holds all values at 'U'? Note: WRITE_ENABLE_FIBRE_REG(0) is assigned in a di...
8 years agoPietervanderStar: There are lots of ways to do it. I originally had it set up as a shift register of arbitrary length, but then simplified it as much as possible before posting in order to not confuse things.
