YogeshThite
4 years agoFor Intel Stratix 10 FPGA, which tool to use to compile ARM53 core code
Using Intel Stratix 10 FPGA - SOC. This contains quad ARM53 cores. Need to write code on one of these ARM53 cores explicitly.
Question:
Need information on which tool to use, where to do...
aikeu
4 years agoHi YogeshThite,
I was trying to reach out to find more relevant information.
1. Is this the generally used procedure?
Yes
2. Is there any IDE that can do end to end code compilation by selecting right compiler at backend?
I not aware that there is any IDE to do that as we normally will compile the required files on external linux environment before program it into the board.
3. Can code be configured to run specific to core for execution?
We do not have any example for reference. Maybe can look into linux taskset cmd for it to be implemented in the code.
https://man7.org/linux/man-pages/man1/taskset.1.html
May I know is your Linux files are programmed into NAND/QSPI/SD flash memory?
Aik Eu
