14 years ago
Floating license walkthrough
This is my first time setting up a license server and I'm a little confused. If I have a floating license are these the right steps to go through?
1. Activate Serial Number through Self Servicing Licensing Center->Activate products
2. Self Servicing Licensing Center->Create New License->Assign Computer->Create new computer. In this section I do either the HOST-ID, NIC, or GUARD-ID of the SERVER that the license server is running on.
3. I copy over a folder called C:\flexlm to the SERVER that contains:
-alterad
-lmgrid
-lmutil
-lmtools
-license.dat (sent in my email)
4. I edit the license.dat file with
SERVER my_server 12345678 <port number> (no port number given so I can leave blank?)
VENDOR alterad "C:\flexlm\alterad.exe"
5. Then I use lmtools->Configuration using Services and link the paths to lmgrd, license.dat, and the debug log.
6. On my laptop I create LM_LICENSE_FILE environment variable and set the value to @my_server. Other users do the same on their laptops.
7. Open Quartus II and check use LM_LICENSE_FILE variable and it should work.
Also, if I have other IP that is tied to my laptop and not the server do I just copy paste the info in the ip_license.dat file that it came with into the license.dat file that I linked to the license server?
