11 years agoFlash issues
Hi. Is there a proper guide that explains how to flash the configuration memory with both hardware and software? Nios II Flash Programmer User Guide 2.2 seems to be outdated. I hope s...
11 years agoHi,
You can try convert the .sof (hardware image) and .elf (software image) files into .jic file format then use QII programmer the .jic file into EPCS. You can refer to these solution link on the steps to generate the .jic file from .sof and .elf files. https://www.altera.com/support/suppo...12006_450.html https://www.altera.com/support/suppo...32010_126.html
