Fixed Value Assignment to Bus in Block Diagram/Schematic File
Q1. How can we assign a fixed value to an input Bus in Block Diagram/Schematic File?
Q2. What is the difference between orthogonal bus tool and diagonal bus tool?
Q3. How can we implement wire assignments in Block Diagram file? e.g wire [99:0] mywire = 100'h12;
- RichardT_altera
Q1. You can try use PARAM primitive. Reference: https://community.intel.com/t5/Intel-Quartus-Prime-Software/How-to-wire-the-PARAM-from-Quartus-primitives-in-a-BDF-file/td-p/47193
Q2. The difference is in the wire style in which one is orthogonal and another is diagonal. Both are bus wire. Orthogonal is mostly used.
Q3. Refer back to Q1.- RichardT_altera
We do not receive any response from you to the previous question/reply/answer that I have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Shyan Yew
