13 years agoFixed point arithmetic not working for digital signal processing application
Hi, I am currently trying to do some simple digital signal processing using the Terasic AD/DA card attached to the Terasic DE0 board (which has a Cyclone III on board). My situation is that I a...
13 years ago --- Quote Start --- The size of my signals do not seem to be the problem though. I have followed the guidelines that are outlined in the .pdf and I still get the same result for my output. --- Quote End --- Convince me - where are your Modelsim simulations of the logic? If you have a difference between simulation and hardware, then it would point to an error in the interface to the DAC, eg., your DAC might not use signed integer format, but straight-binary (which requires inverting the MSB of the data before sending it to the DAC). Cheers, Dave
