13 years agoFixed point arithmetic not working for digital signal processing application
Hi, I am currently trying to do some simple digital signal processing using the Terasic AD/DA card attached to the Terasic DE0 board (which has a Cyclone III on board). My situation is that I a...
13 years agoThank you for your documents. I will keep them at hand.
The size of my signals do not seem to be the problem though. I have followed the guidelines that are outlined in the .pdf and I still get the same result for my output. Moreover, the output waveform does not look like a sine with a horizontal "cut" at some height (notice that the cut seems asymmetric). This suggests to me that there is somethign else than a bit-width problem.
