kanthi
7 years agoFitter routing can't fit into device when we look the resource utilization is less than 60%. we are using stratix V device. how to fix this.
Error (11802): Can't fit design in device. Modify your design to reduce resources, or choose a larger device. The Altera Knowledge Database contains many articles with specific details on how to reso...
KennyT_altera
7 years agoDid see the failure in the platform designer interconnect? If yes, there are 3 ways to solve it
1) in qsys -> press system -> show system with interconnect -> memory mapped interconnect -> manually add register there
2) in your qsys, add pipeline register module
3) go to interconnect requirement-> limit interconnect requirement -> increase it
Qsys automatic add adapter when there are mismatch btw the avalon. You cannot simply remove those adapter as it will cause your function to be broken. Thanks
