fit.rpt message
I compile my project,I find there are the following message in my porject.fit.rpt file.
I don't know the message meaning , and what does it influence ?
Note: For more information on problematic transfers, consider running the Fitter again with the Optimize hold timing option (Settings Menu) turned off.
This will disable optimization of problematic paths and expose them for further analysis using the Timing Analyzer.
- sstrell
This is just a generic message. If your design is meeting timing, you don't need to do anything.
- Nurina
Hi, did the above comment help?
- poming
Yes,thank you.
- Nurina
