Hi fabf.
The don't care '-' and 'X' are non synthesizable metavalues so don't use it. You can't use it like Karnaugh map o true table don't care. To replace it you have assigment sentences with priority, like when o if-elsif-else. I'll use if. For example you have:
when "01XXXXXXXX00XXXX" => dq(8 downto 1) <= "01111111";
You can code it:
process...
begin
if( a(15 downto 14) = "01" and a(5 downto 4) = "00" ) then
elsif( .....
The first if only use bits 4, 5, 14, 15. Don't look other bits. So they don't care, and the other if are not evaluated. This way you can write a synthesizable code with don't care. You have to unroll the original true table with the don't cares and translate into vhdl.
