8 years agoFirst VHDL project and i am having plenty of problems.
I am trying to write a code that displays weight and height on a 7 segment display depending on the push button that is pressed. I am using clk and clk2 as the push button. F0 and F1 represe...
8 years agoi did this instead
F1<=
"0000001" WHEN weight="00000" AND clk='1' else
"0000001" WHEN weight="00001" AND clk='1' else
"0000001" WHEN weight="00010" AND clk='1' else
"0000001" WHEN weight="00011" AND clk='1' else
"0000001" WHEN weight="00100" AND clk='1' else
"0000001" WHEN weight="00101"AND clk='1' else
"0000001" WHEN weight="00110" AND clk='1' else
"0000001" WHEN weight="00111" AND clk='1' else
"0000001" WHEN weight="01000" AND clk='1' else
"0000001" WHEN weight="01001" AND clk='1' else
"1001111" WHEN weight="01010" AND clk='1' else
"1001111" WHEN weight="01011" AND clk='1' else
"1001111" WHEN weight="01100" AND clk='1' else
"1001111" WHEN weight="01101" AND clk='1' else
"1001111" WHEN weight="01110" AND clk='1' else
"1001111" WHEN weight="01111" AND clk='1' else
"1001111" WHEN weight="10000" AND clk='1' else
"1001111" WHEN weight="10001" AND clk='1' else
"1001111" WHEN weight="10010" AND clk='1' else
"1001111" WHEN weight="10011" AND clk='1' else
"0010010" WHEN weight="10100" AND clk='1' else
"0010010" WHEN weight="10101" AND clk='1' else
"0010010" WHEN weight="10110" AND clk='1' else
"0010010" WHEN weight="10111" AND clk='1' else
"0010010" WHEN weight="11000" AND clk='1' else
"0010010" WHEN weight="11001" AND clk='1' else
"0010010" WHEN weight="11010" AND clk='1' else
"0010010" WHEN weight="11011" AND clk='1' else
"0010010" WHEN weight="11100" AND clk='1' else
"0010010" WHEN weight="11101" AND clk='1' else
"0000110" WHEN weight="11110" AND clk='1' else
"0000110" WHEN weight="11111" AND clk='1' else
"0000001" WHEN height="00000" AND clk2='1' else
"0000001" WHEN height="00001" AND clk2='1' else
"0000001" WHEN height="00010" AND clk2='1' else
"0000001" WHEN height="00011" AND clk2='1' else
"0000001" WHEN height="00100" AND clk2='1' else
"0000001" WHEN height="00101" AND clk2='1' else
"0000001" WHEN height="00110" AND clk2='1' else
"0000001" WHEN height="00111" AND clk2='1' else
"0000001" WHEN height="01000" AND clk2='1' else
"0000001" WHEN height="01001" AND clk2='1' else
"1001111" WHEN height="01010" AND clk2='1' else
"1001111" WHEN height="01011" AND clk2='1' else
"1001111" WHEN height="01100" AND clk2='1' else
"1001111" WHEN height="01101" AND clk2='1' else
"1001111" WHEN height="01110" AND clk2='1' else
"1001111" WHEN height="01111" AND clk2='1' else
"1001111" WHEN height="10000" AND clk2='1' else
"1001111" WHEN height="10001" AND clk2='1' else
"1001111" WHEN height="10010" AND clk2='1' else
"1001111" WHEN height="10011" AND clk2='1' else
"0010010" WHEN height="10100" AND clk2='1' else
"0010010" WHEN height="10101" AND clk2='1' else
"0010010" WHEN height="10110" AND clk2='1' else
"0010010" WHEN height="10111" AND clk2='1' else
"0010010" WHEN height="11000" AND clk2='1' else
"0010010" WHEN height="11001" AND clk2='1' else
"0010010" WHEN height="11010" AND clk2='1' else
"0010010" WHEN height="11011" AND clk2='1' else
"0010010" WHEN height="11100" AND clk2='1' else
"0010010" WHEN height="11101" AND clk2='1' else
"0000110" WHEN height="11110" AND clk2='1' else
"0000110" WHEN height="11111" ;
F0<= "0000001" WHEN weight="00000" AND clk='1' else
"1001111" WHEN weight="00001" AND clk='1' else
"0010010" WHEN weight="00010" AND clk='1' else
"0000110" WHEN weight="00011" AND clk='1' else
"1001100" WHEN weight="00100" AND clk='1' else
"0100100" WHEN weight="00101" AND clk='1' else
"0100000" WHEN weight="00110" AND clk='1' else
"0001111" WHEN weight="00111" AND clk='1' else
"0000000" WHEN weight="01000" AND clk='1' else
"0000100" WHEN weight="01001" AND clk='1' else
"0000001" WHEN weight="01010" AND clk='1' else
"0010010" WHEN weight="01100" AND clk='1' else
"0000110" WHEN weight="01101" AND clk='1' else
"1001100" WHEN weight="01110" AND clk='1' else
"0100100" WHEN weight="01111" AND clk='1' else
"0100000" WHEN weight="10000" AND clk='1' else
"0001111" WHEN weight="10001" AND clk='1' else
"0000000" WHEN weight="10010" AND clk='1' else
"0000100" WHEN weight="10011" AND clk='1' else
"0000001" WHEN weight="10100" AND clk='1' else
"1001111" WHEN weight="10101" AND clk='1' else
"0000110" WHEN weight="10111" AND clk='1' else
"1001100" WHEN weight="11000" AND clk='1' else
"0100100" WHEN weight="11001" AND clk='1' else
"0100000" WHEN weight="11010" AND clk='1' else
"0001111" WHEN weight="11011" AND clk='1' else
"0000000" WHEN weight="11100" AND clk='1' else
"0000100" WHEN weight="11101" AND clk='1' else
"0000001" WHEN weight="11110" AND clk='1' else
"1001111" WHEN weight="11111" AND clk='1' else
"1001111" WHEN height="00001" AND clk2='1' else
"0010010" WHEN height="00010" AND clk2='1' else
"0000110" WHEN height="00011" AND clk2='1' else
"1001100" WHEN height="00100" AND clk2='1' else
"0100100" WHEN height="00101" AND clk2='1' else
"0100000" WHEN height="00110" AND clk2='1' else
"0001111" WHEN height="00111" AND clk2='1' else
"0000000" WHEN height="01000" AND clk2='1' else
"0000100" WHEN height="01001" AND clk2='1' else
"0000001" WHEN height="01010" AND clk2='1' else
"0010010" WHEN height="01100" AND clk2='1' else
"0000110" WHEN height="01101" AND clk2='1' else
"1001100" WHEN height="01110" AND clk2='1' else
"0100100" WHEN height="01111" AND clk2='1' else
"0100000" WHEN height="10000" AND clk2='1' else
"0001111" WHEN height="10001" AND clk2='1' else
"0000000" WHEN height="10010" AND clk2='1' else
"0000100" WHEN height="10011" AND clk2='1' else
"0000001" WHEN height="10100" AND clk2='1' else
"1001111" WHEN height="10101" AND clk2='1' else
"0000110" WHEN height="10111" AND clk2='1' else
"1001100" WHEN height="11000" AND clk2='1' else
"0100100" WHEN height="11001" AND clk2='1' else
"0100000" WHEN height="11010" AND clk2='1' else
"0001111" WHEN height="11011" AND clk2='1' else
"0000000" WHEN height="11100" AND clk2='1' else
"0000100" WHEN height="11101" AND clk2='1' else
"0000001" WHEN height="11110" AND clk2='1' else
"1001111" WHEN height="11111" AND clk2='1';
and it works thanks for the help.
