8 years agoFirst VHDL project and i am having plenty of problems.
I am trying to write a code that displays weight and height on a 7 segment display depending on the push button that is pressed. I am using clk and clk2 as the push button. F0 and F1 represe...
8 years agoits not really a clock , i dont know why i called it clk i am just used to it.
its just a signal to choose which output to show. i think my problem is the With-Select inside a process. What can i replace it with. or can i use something else other than an if function ? i tried ANDing but it isnt working.
