Lorne_K_Intel
5 years agoFirmware revision 0x000a on channel 0 is not supported
quartus 20.2 build 50.60/11/2020
Firmware revision 0x000a on channel 0 is not supported when loading e-tile toolkit.
E-tile parameter change to 10G implementation caused e-tile toolkit to not load.
Hundreds of e-tile example designs were built and loaded successfully until this configuration.
- Deshi_Intel
2 Warning found in EHIP IP
- Deshi_Intel
- Can you share full screenshot of the error message ?
- When you mentioned E-tile toolkit, are you referring to transceiver toolkit ?
- May I know are you using Intel FPGA dev kit board or your own custom board ?
- Your quartus design FPGA OPN shown you are using ES silicon device - VGS1
- ES silicon device is not meant to support all feature in long run.
- Do you have S10 production device to try out ?
- I noticed you have some warning in EHIP IP setting. Can you clean up the warning and then retry toolkit ?
- Can you also try out toolkit with latest Quartus version v20.4. Compile design with v20.4 and open toolkit in v20.4
dlim
- Deshi_Intel
HI,
I am setting this case to closure since I haven't hear back from you for more than 2 weeks.
Hopefully things is working on your side.
Feel free to post new forum thread if you still required help in future.
Deshi
