JordanD
5 years agoFIR II Decimation Frequency Response
I'm designing a filter with the FIR II IP. Input data rate is 64 MHz and decimation factor is 8. I want the frequency response to be low pass cut off at 3.2 MHz.
The confusing thing is whether the ...
CheepinC_altera
5 years agoHi,
Thanks for sharing the new file. For your information, I still get into error in Matlab with the file which I believe is related to the +=, .*, /= operators in the file. I did a search in web and seems like these operators are not supported. Would you mind to help changing to the Matlab compatible operators? Thank you.
- JordanD5 years ago
Apologies, attached I believe I have removed all such operators.
