JordanD
5 years agoFIR II Decimation Frequency Response
I'm designing a filter with the FIR II IP. Input data rate is 64 MHz and decimation factor is 8. I want the frequency response to be low pass cut off at 3.2 MHz.
The confusing thing is whether the ...
CheepinC_altera
5 years agoHi,
Thanks for your help. By the way, as I run the fir_inspect.m in the Matlab 2018b, I encountered the following error:
Error: File: fir_inspect.m Line: 5 Column: 15
Invalid use of operator.
Not sure if I miss out anything.
- JordanD5 years ago
Apologies, please change the ** operator to ^ (attached).
