12 years ago
find the max value between a given inputs
hi all
i need a vhdl code to find the max value from integer input where i have a four input ??
thanks a lot
    first start off with behavioral coding which is mostly like c using > symbol...
    once u done with that move on to dataflow
    i have a 4 inputs every input has only one value such as
    a => 100
    b => 200
    c => 300
    d => 400
    i want to find max value between a,b,c,d should be d <= 400
    how i can make it in vhdl code??
    how about compare between 2 inputs first and then the other 2 inputs and the results will e compare
    is it a logic idea can e executed
    you are on right track...
    now design a circuit which compares two inputs and gives out the largest one
    there were many ways to design this. One way can be design comparator and Mux circuits and choose the selection pin of mux based on logic
