10 years agoFilter VHDL
Hi, I've designed a filter pass low with 64 taps. I am not sur about my coding and I will be grateful if someone correct or confirm my vhd file. I have some doubts about the output signal. An...
10 years agoHi,
I had a quick review of your code. First answer few questions: 1. Where are your filter coeficients? Are you trying implement moving average filter? 2. What type of filter you are trying to implement? FIR (Finite Impulse Response ) or IIR (Infinite inpulse response)? Some comments on your code: Your code sums up input signal 64 times with itself. For eg. if signal_in=1 then you will get DOUT(63)=64. This is not how digital filters works.
