AAnch
7 years agoFile Descriptor Handle for internal Flash on Max10 FPGA
I wanted to perform write and reads on the internal flash of the Max10 FPGA. Using the below code the file handle is getting zero return from this function (i have ensured that Flash device name matc...
AAnch
7 years agoI see this error message while simulating the C code with modelsim. So could you please check if the above C code can be simulated for Max 10 FPGA?
