AAnch
7 years agoFile Descriptor Handle for internal Flash on Max10 FPGA
I wanted to perform write and reads on the internal flash of the Max10 FPGA. Using the below code the file handle is getting zero return from this function (i have ensured that Flash device name matc...
Ahmed_H_Intel1
7 years agoHi,
Can you download the BUP design from here
And then open the Eclipse>New>NIOS II application and BSP from template>choose the memtest template
Run this test and see if you will get the same error. This should be working fine
Please also check SW1 and SW2 in the bottom of the board.
