18 years agoWhen you have your .vwf file open, go to Edit -> End Time. How long the simulator runs and how long your simulation input file is are two different things. (Makes more sense in the reverse, where you might have a really long input .vwf, but only want to run the simulator for a portion of that time.
The second part needs more info/debugging. Just saying the simulation wasn't working doesn't help a lot. Are you not getting outputs(something wrong with the setup), or do you get output transitions, just not what you expect, and think it's functionally incorrect?
