Fatal Error: Access Violation at 0X00007FFCA1DCA69C
When I installed and used Quartus Prime ver18.1, it occurred in "Analysis & Synthesis".
Please tell me how to resolve this error.
I am using 18.1 to match the environment with the existing project.
The contents of the error file are as follows.
Problem Details
Error:
*** Fatal Error: Access Violation at 0X00007FFCA1DCA69C
Module: quartus_map.exe
Stack Trace:
0x1a69b: HDB_SOURCE_FILE::get_library + 0x3 (DB_HDB)
0x6744c: SGN_QIC_UTILS::create_new_hierarchy_info + 0xe8c (synth_sgn)
0xb75ae: SGN_EXTRACTOR::recursive_extraction + 0x28e (synth_sgn)
0xb6e6f: SGN_EXTRACTOR::recurse_into_newly_extracted_netlist + 0x36f (synth_sgn)
0xb757b: SGN_EXTRACTOR::recursive_extraction + 0x25b (synth_sgn)
0xb08c3: SGN_EXTRACTOR::extract + 0x1d3 (synth_sgn)
0x1324e: sgn_qic_full + 0x19e (synth_sgn)
0x4351: qsyn_execute_sgn + 0x131 (quartus_map)
0x13f9c: QSYN_FRAMEWORK::execute_core + 0x12c (quartus_map)
0x13aa6: QSYN_FRAMEWORK::execute + 0x496 (quartus_map)
0x112bc: qexe_do_normal + 0x1ec (comp_qexe)
0x16142: qexe_run + 0x432 (comp_qexe)
0x16e51: qexe_standard_main + 0xc1 (comp_qexe)
0x1b08b: qsyn_main + 0x51b (quartus_map)
0x12e98: msg_main_thread + 0x18 (CCL_MSG)
0x1467e: msg_thread_wrapper + 0x6e (CCL_MSG)
0x16660: mem_thread_wrapper + 0x70 (ccl_mem)
0x12761: msg_exe_main + 0xa1 (CCL_MSG)
0x29872: __tmainCRTStartup + 0x10e (quartus_map)
0x17033: BaseThreadInitThunk + 0x13 (KERNEL32)
0x52650: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus_map
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
- SyafieqS
Hi Mitsuo,
Can you attach a small test design here .qar for me to replicate the issue.
This might be a valid bug.
- Mitsuo3314
Hi SyafieqS.
Thank you for your reply.
I attached .qar file.
This qar file is similar to the hdmi sample.
Add one piece of information.
I moved it on another PC, and this Fatal did not occur.
Next, I moved it to another folder and checked it, and this Fatal did not occur.
Therefore, it is considered that the problem depends on the corresponding folder,and I think this problem is solved.
Mitsuo
- SyafieqS
Mitsuo,
Thank you for the file..
Let me know if the workaround not feasible for you as by changing the folder or machine as you mentioned.
- SyafieqS
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
