8 years agoFalse path question - internal counter bit vs FSM state bit
Dear Altera Forum members... This is my first post here :) I have a sub-circuit that consists of a binary up-counter (LPM_counter) with asynchronous reset and count enable, and a comparator (LP...
8 years agoThe failing path is between the counter and state machine via the compare. Is it possible to pipeline the compare?
The Max devices are not very fast, so I can only assume the compare is a little too much in the path.
