Failed to generate sof with error: Unlicensed IP: "Nios II Processor(6AF7 00A2)"
Which version of the NIOS2 processor are you using - NIOS2 - e/f? The 'e' variant is free while the 'f' is licensed. If you do not have a license for the NIOS2/f variant, then change it to NIOS2/e and compile. It should work.
- Jiayi_H_Intel7 years ago
I do have Nios license. And when running assembler, quartus will require twice with 1 successful and 1 unsuccessful.
; Assembler Encrypted IP Cores Summary ;
; Vendor ; IP Core Name ; License Type ;
; Altera ; Nios II Processor (6AF7 00A2) ; Unlicensed ;
; Altera ; Nios II Processor (6AF7 00A2) ; Licensed ;
; Altera ; 16550 UART (6AF7 010C) ; Licensed ;
; Altera ; Signal Tap (6AF7 BCE1) ; Unlicensed ;
; Altera ; Signal Tap (6AF7 BCE1) ; Licensed ;
; Altera ; Signal Tap (6AF7 BCEC) ; Licensed ;
; PLD Applications ; altera (73E1 3000) ; Unlicensed ;
; PLD Applications ; xpressrich3_synth_BoardEval (73E1 3EA3) ; Unlicensed ;
