12 years ago
fail to compile arria dev board example bts_config
trying to compile the dev board example bts_config the compilation faild due to :
Error (12006): Node instance "bup_nios_inst" instantiates undefined entity "bup_nios"
Error: Quartus II 32-bit Analysis & Synthesis was unsuccessful. 1 error, 5 warnings
Error: Peak virtual memory: 391 megabytes
Error: Processing ended: Tue Jun 10 13:04:23 2014
Error: Elapsed time: 00:00:13
Error: Total CPU time (on all processors): 00:00:03
Error (293001): Quartus II Full Compilation was unsuccessful. 3 errors, 5 warnings
I thought all the examples for the dev board should compile and run. Am I right ?
If yes what is missing?
Jacob
1 Reply
    Hi Jacob,
    You have to build bup_nios.qip before compilation. Go to Tools->SOPC builder, it should open bup_nios.sopc for you. Now click "Generate", the SOPC builder will generate the missing files.
    Cheers,
    Xing
