8 years agoExtraordinary long compilation time
Hello all. I am compiling a relatively simple OpenCL kernel for computing SHA-1 hashes. I've optimized and got everything working under the emulator and began building an AOCX file. That was ov...
8 years ago12 days is definitely not normal. Anything beyond 24 hours is not normal and likely a sign of routing congestion which means the kernel will likely never route. Based on your other thread, the fact that you have 32 GB of memory which is not enough for large Arria 10 designs, and are instead making up for it by using a large swap size, could also lead to such long compilation time. You can check the compilation folder and sort the files based on time and check the last report. top.fit.rpt is the fitting report, but it is not updated regularly. The content of all the reports is also reflected in the "quartus_sh_compile.log" file one after the other.
