External memory Interface Intel Cyclone 10 FPGA IP configure DATA bus size from Avalon MM interface
- 7 years ago
Hi ADona,
Cyclone 10 GX package only support DDR3 x40 with ECC. This information cover in “Intel® Cyclone® 10 GX Core Fabric and General Purpose I/Os Handbook” page 166.
So, you need to turn on the “Enable Error Detection and Correction Logic with ECC” under the “Controller” setting in order to use DDR3 x40.
Another option is you can use 32 DQ width and you can see now the amm interface become 256bits.
Hope this helps.
NAli1
Hi ADona,
Hope this helps.
NAli1
Thanks, that works.
