15 years agoexporting parameters and manipulating dimension of a BDF design in Quartus II
Q1. This concerns the issue of fully 'parametrizing' a design so that the parameter to be exported can be set at the top-most level in a project. For example number of bits at the o/p of an ADC (8 bits, 10 bits, 12 bits, and so forth). Furthermore the project comprises of a lot of multiple hierarchies of BDF modules/sub-modules. Clearly it is too much work to build one design per one setting of a parameter (ADC bits in this case, but could have more parameters). Also, I am not looking to 'massage' the generated code in HDL domain via defParam. This is a Quartus 'design entry' type of question. The goal is to create a parametrized design, so that any number of 'variant-designs' can be generated at will, perform subsequent compilation of the design, and use the existing logic lock bounding boxes, etc. Q2. If there is a way to tackle Q1, the next question is ...How to change the port dimension associated with an existing port so that it is a function of a passed in parameter. For instance an output port associated with a block : how to change out_bits[11..0] to something like out_bits[passed_in_dim..0], where passed_in_dim is an exported parameter. Q3. Assuming there are no workarounds for Q1, and Q2, the only other thing that comes ti my mind is to develop Tcl/Tk scripts that queries the design, obtains the Instance Id of the block, pushes into the instance, gets handle on the parameters, ports, etc changes parameters, modifies port dimension (based on parameter value)....all via the Tcl/Tk script. In other words the final deliverable then would be the a) The BDF design b) The Tcl/Tk parametrization script with the provision to pass-in the required ADC bits. Can anyone point me to a tutorial chapter describing the process. Thanks
