15 years agothank you both
regarding the modifications of the generated files, I think I can generate once a IRQ receiver, edit the generated file to export the signal, and then create a new module in the SOPC builder and use the include HDL files option. this way I don't have to redo this work every time I generate the SOPC system. any thoughts on that? BadOmen, I didn't understand the note you added. the DMA should behave the same, only the IRQ have to drive 2 destination the NIOS and the outer world (through some work around)
