11 years agoExport Waveform/vector File (.VWf) as VHDL Testbench
Hello all, I use recently Quartus II 14.0 (QuartusSetupWeb-14.0.0.200-windows 64 bit) I would like generate a Test bench Output files .Vht from Waveform/vector File .VWf I created but I wa...
11 years agoYOu cannot use this to generate the testbench, you need to observe what command that had been used in the .vwf file and change the option from vht vt. something like -vhdl to - verilog. And use command prompt to insert the full command for the generation of testbench
