--- Quote Start ---
If you change an _hw.tcl file, you *ALSO* have to re-run ip-make-ipx in the base directory containing the .ipx file. Eg., on the machine I am on I have an old web version ...
C:\software\altera\12.1sp1_free\ip\altera\altera_components.ipx
You need to start a NIOS II IDE shell (cygwin console), change to this directory, run ip-make-ipx, and then rename the generated components.ipx file.
I think that should do the trick ... at least it does for the Qsys stuff ... not sure about SOPC Builder _hw.tcl files though.
Cheers,
Dave
--- Quote End ---
I did remake the components.ipx, regenerate my system, and remade the bsp. No luck so far. I also attempted to make my own custom bridge component and am trying to make that show up in system.h. No luck so far. The annoying thing is I have a bunch of custom components that come out fine, just haven't found the magic property yet.
I did find this reference though which has some of the properties, but not all.
http://www.altera.com/literature/hb/qts/qsys_tcl.pdf Here is what was in the _hw.tcl file for altera_avalon_mm_bridge
set_module_property DESCRIPTION "Inserts a register stage in the Avalon-MM command and response paths. Accepts commands on its Avalon-MM slave port and propagates them to its Avalon-MM master port."
set_module_property NAME altera_avalon_mm_bridge
set_module_property VERSION 13.1
set_module_property HIDE_FROM_SOPC true
set_module_property GROUP "Bridges and Adapters/Memory Mapped"
set_module_property AUTHOR "Altera Corporation"
set_module_property DISPLAY_NAME "Avalon-MM Pipeline Bridge"
set_module_property TOP_LEVEL_HDL_FILE altera_avalon_mm_bridge.v
set_module_property TOP_LEVEL_HDL_MODULE altera_avalon_mm_bridge
set_module_property INSTANTIATE_IN_SYSTEM_MODULE true
set_module_property EDITABLE true
set_module_property ELABORATION_CALLBACK elaborate
set_module_property ANALYZE_HDL FALSE
set_module_property SIMULATION_MODEL_IN_VHDL true
set_module_property DATASHEET_URL http://www.altera.com/literature/hb/qts/qsys_interconnect.pdf
And here is what I changed it to:
set_module_property HIDE_FROM_SOPC false
set_module_property INTERNAL false
