11 years ago
Export Avalon Bus for Custom PHY
I would like to connect the Custom PHY Megafunction to my QSYS system. Well, [rant]OK, really: first I got to get this off my chest: I think it is just so ridiculous, that Altera did not make the Custom PHY QSYS compliant by themselves - it's just a massive waste of everyone's time, come on![/rant]
  1. I am using the pipeline bridge to make myself a nice conduit signal outside of QSYS
  2. I am using word adressing
  3. I set the address width of the pipeline bridge to 9, which corresponds to the Address width of the Custom PHY
  4. Symbol width??? What's that?
  5. I hook the signals together
  6. The bus stalls (or at least that's what I think it does, because I can't find my system ID in NIOS when I do this)
So: What am I doing wrong (technically I mean, not by relying on Altera in the first place). I would attach pictures of my design, but the uploader doesn't work.
Cheers, Peter
    If you change an _hw.tcl file, you *ALSO* have to re-run ip-make-ipx in the base directory containing the .ipx file. Eg., on the machine I am on I have an old web version ...
    C:\software\altera\12.1sp1_free\ip\altera\altera_components.ipx
    You need to start a NIOS II IDE shell (cygwin console), change to this directory, run ip-make-ipx, and then rename the generated components.ipx file.
    I think that should do the trick ... at least it does for the Qsys stuff ... not sure about SOPC Builder _hw.tcl files though.
    Cheers,
    Dave
    --- Quote Start ---
    Cheers,
    Dave
    --- Quote End ---
    I did remake the components.ipx, regenerate my system, and remade the bsp. No luck so far. I also attempted to make my own custom bridge component and am trying to make that show up in system.h. No luck so far. The annoying thing is I have a bunch of custom components that come out fine, just haven't found the magic property yet.
    I did find this reference though which has some of the properties, but not all. http://www.altera.com/literature/hb/qts/qsys_tcl.pdf
    Here is what was in the _hw.tcl file for altera_avalon_mm_bridge
    set_module_property DESCRIPTION "Inserts a register stage in the Avalon-MM command and response paths. Accepts commands on its Avalon-MM slave port and propagates them to its Avalon-MM master port."
    set_module_property NAME altera_avalon_mm_bridge
    set_module_property VERSION 13.1
    set_module_property HIDE_FROM_SOPC true
    set_module_property GROUP "Bridges and Adapters/Memory Mapped"
    set_module_property AUTHOR "Altera Corporation"
    set_module_property DISPLAY_NAME "Avalon-MM Pipeline Bridge"
    set_module_property TOP_LEVEL_HDL_FILE altera_avalon_mm_bridge.v
    set_module_property TOP_LEVEL_HDL_MODULE altera_avalon_mm_bridge
    set_module_property INSTANTIATE_IN_SYSTEM_MODULE true
    set_module_property EDITABLE true
    set_module_property ELABORATION_CALLBACK elaborate
    set_module_property ANALYZE_HDL FALSE
    set_module_property SIMULATION_MODEL_IN_VHDL true
    set_module_property DATASHEET_URL http://www.altera.com/literature/hb/qts/qsys_interconnect.pdf
    And here is what I changed it to:
    set_module_property HIDE_FROM_SOPC false
    set_module_property INTERNAL false
    Oh there was also a part in the actual interface description which I didn't see in other modules.
    set_interface_property s0 printableDevice false
    I couldn't find any info on this property, but I tried removing this too and so far no luck.
    It is possible that my system isn't picking up the new components.ipx file properly, haven't been able to confirm that yet.
    --- Quote Start ---
    --- Quote End ---
    Hit F5 to reload the components files, or exit Qsys and restart.
    You could add a text message to the _hw.tcl file you are editing too, and then look for that message in the "Generate" console, eg.,
    send_message info " *** INSERT MESSAGE HERE *** "
    Cheers,
    Dave
    Ok so I've gotten around my issue finally. I created a custom addressable bridge component by copying the altera bridge and making some _hw.tcl changes.
    The key thing is removing the
     set_interface_property s0 bridgesToMaster m0
    property in the avalon interface description.
    This changes
    <isBridge>true</isBridge>
    to
    <isBridge>false</isBridge>
    which makes it show up in the system.h file. Obviously I didn't want all bridges to appear so that's why I made a custom bridge.
    Hope this helps anyone that stumbles across this later.
