11 years agoI'm guessing that is both a question and the answer :)
You can read the _hw.tcl file to determine the logic behind the signals. If the clocks were showing up as conduits vs clocks, then the interface definitions in the Tcl likely change depending on another option. Some components are constructed using Tcl callbacks ... the code is not that easy to follow "for fun", but if you're tracking down a specific signal, it shouldn't be too hard to follow. Cheers, Dave
