11 years agoHi Dave,
--- Quote Start --- I already told you --- Quote End --- Sorry, for not thinking for myself! It was only after I had posted, that I just saw you said I should right-click on the component in QSYS. The IP root folder was located inaltera_install_dir/ip/altera on my machine. Many thanks, Dave!!!! Now the beast shows up in QSYS! --- Quote Start --- As for what is wrong with what you did above? My answer would be that you did not simulate using the Verification IP - that would answer any questions you have about the interface working correctly --- Quote End --- That is indeed true ;) Cheers, Peter
