11 years ago --- Quote Start --- Where do I find those files. --- Quote End --- I already told you :) Download the Transceiver Toolkit examples from the link I referred to above (they were designed with 13.0sp1, but should open ok in 13.1). Open one of the existing Cyclone V projects and look at the path to the PHY. That will show you where in the Quartus installation the components are located. --- Quote Start --- Is the idea, that I have to do this for every project, or once for my Quartus installation? --- Quote End --- Just for your Quartus installation. Basically you are making the components visible to all projects. As for what is wrong with what you did above? My answer would be that you did not simulate using the Verification IP - that would answer any questions you have about the interface working correctly :) Cheers, Dave
