13 years ago
Explicitly leave pins unassigned in Quartus?
There are pins in the ports of my top level entity that I do not want assigned to any pin, but I don't want the fitter auto-assigning them for me. Is there a way to designate a port as "do not assign" - my top level entity is something that is used to varying degrees in several different designs, and in some designs more of the ports are used than others. Any thoughts here?
-R
    One way is to use a wrapper that has only the ports that you require and bury others inside. I assume you mean outputs which can be left open. For inputs you may run into trouble if undriven.
    There is also the setting of virtual pin but I am not sure if it is good for your purpose.
    You can set them as virtual in the assignment editor and you no-long map to an io port
