14 years agoOk - the solution (process(all) to question 1 causes the simulator to go to lala land.
The code is entity foo is generic ( gen_var : integer; ); port ( ... ); end entity architecture arch of foo is signal val : std_logic_vector ( 3 downto 0 ); process(all) begin case (gen_var) is when 0 => val <= B"0010"; when 1 => val <= B"0101"; ... when others => val <= B"0110"; end case; end process; end; If I use process(rst_l) --rst_l is another input to the module it's fine, but process(all) tanks. thoughts? thanks! /j
