14 years ago1) Use process(all) or use a "when" assignment
2) Still ugly. You're simply not allowed to read from an 'output' in VHDL. If you need to read back the value of a module's output, you need to use an internal signal instead and then assign that internal signal to the output. Example: library ieee; use ieee.std_logic_1164.all; entity vhdl_tm is port ( clk : in std_logic; x : in std_logic; y : out std_logic ); end vhdl_tm; architecture rtl of vhdl_tm is signal y_internal : std_logic; begin process(clk) begin if rising_edge(clk) then if x = '1' then y_internal <= '0'; else y_internal <= not y_internal; end if; end if; end process; y <= y_internal; end;
