dsun01
Contributor
4 years agoexec elab_debug error
Dear Support,
I have a project from Texas Instruments. I am learning how to port it to Intel A10 GX development board. I use Quartus Pro 21.3 Generate Simulator Setup Script created a TCL. and i...
- 4 years ago
Hi David,
Thanks for the project file. I will try to replicate the issue and update to you.
Pavee
dsun01
Contributor
4 years agoDear Support,
In the msim_setup.tcl in the last post. there are few places I don't understand.
1. the TCL assigne loopback_fifo as the top_level_name. I don't understand why, loopback_fifo is just one the IP used in the system, not top testbench. can I change it to the real top level testbench.?
if ![info exists TOP_LEVEL_NAME] {
set TOP_LEVEL_NAME "loopback_fifo.loopback_fifo"
2. how do I add the testbench_top.v to the .tcl where should I put the testbench_top.v file so the .tcl will find it.
thanks,
David
