BPani1
7 years agoEthernet ping issue with Arria 10 Development Kit
Hi , I am using quartus prime-18.1 version and Arria 10 Development kit(Serial Number:10APCIe0002691) . I am trying to ping the ethernet from the host which is connected one to one. I have assigne...
Deshi_Intel
7 years agoHi Biswajit,
You may want to try with lower level debug on TSE MAC first. Example like performing loopback testing to see where is the failure point.
1) Loopback within TSE IP
2) Loopback on External PHY chip
3) Then only finally loopback on external host side if possible
If loopback is working then most likely is your higher software application layer issue.
dlim
- BPani17 years ago
Hi ,
Thanks alot for your reply.But please explain how to perform the loopback within the TSE IP and on External PHY chip.
If i can get the reference design for the EVM which can compiled on 18.1 will be helpful.
Biswajit
