Altera_ForumHonored Contributor15 years agoError:TRI or OPNDRN buffers permanently enabled 1.Warning: TRI or OPNDRN buffers permanently enabled 2.Warning (10235):variable "readMem" is read inside the Always Construct but isn't in the Always Construct's Event Control 3.Warning (10272):...Show More
Altera_ForumHonored Contributor15 years agothank you very much,I need to check the codes more carefully.
Recent DiscussionsInvalid license key (inconsistent authentication code)Regarding the issue of UFM not startingram retimingReset Release IP for Agilex needs Stratix 10 device files installed!Licensing ‘Know-How’ Guide
