Errors with parametrized instantiation of custom componenten in platform designer
- 5 years ago
thank you for the answer! At first the behavior didn't change with the strings but then I added the lines
set_parameter_property <parameter_name> HDL_PARAMETER truefor all the parameters. Now the Fitter doesn't output any error messages no more.
Florian
According to the Platform Designer user guide, the value for WIDTH_EXPR should be a string representing the name of the parameter (page 701) you want to use (for you "g_adr_width"). You can see an example of this on page 100:
Also, if this doesn't fix the issue, can you show the other commands in your _hw.tcl for the port in question, asi_data_channel_i?
- FHint5 years ago
Florian- RichardT_altera5 years ago
