Error:"Connected system ID hash not found on target at expected base address"
Hi @vietvu1912,
Thank you for posting in Intel community forum and hope all is well.
Mind if I ask did you managed to programmed the correct sof successfully? Which quartus version and board are you using?
Would suggest on the following, check on the system.h files in BPS project to ensure system ID peripheral are listed with correct value, followed by regenerating the BSP to see if that helps.
As running the program in hardware, try to refresh the connection under 'Target Connections' tab.
You may also try checking 'Ignore mismatched system ID & timestamp' fields and run to the program to see if that helps.
Hope to hear form you soon.
Best Wishes
BB
- vietvu19125 years ago
Hello, thanks for your reply.
I created a file that is identical to the qsys file of the project I downloaded from Intel and only removed the IPcore Triple speed Ethernet I don't use. I don't know if my .qsys is missing anything from that project, but every connection and IPcore I have installed is the same.
i use quartus pro 18.0 and my board is Cyclone 10Gx development kit.
can you tell me what is the peripherial ID representation value in system.h?
I also try checking 'Ignore mismatched system ID & timestamp' but .elf file download failed. I have refreshed the connection but Connected System ID and Connected system timestamp are still not found.
Can you support for me to solve this?
A project I downloaded from Intel and the system ID properties notification image is attached below:
