OlegTerentiev
5 years agoError(16904) an enum variable may only be assigned to same enum typed variable or one of its values
Hi, Intel
In attach two project - completely identical, but
one made in Quartus 21.1 Standart and it is synthesized,
second made in Quartus 21.1 PRO - the synthesis is not completed due to an e...
OlegTerentiev
5 years agoGood afternoon again, Intel !
In first message i made one mistake - used version Quartus 20.1.1 Standart - last version.
Ok, this is really important to us - we decided to take the aligned versions - Pro, Standard and Lite - release 20.1, Release date: June, 2020
The situation is completely similar - Standard and Lite working well, Pro stopped with error - projects in attachment.
As I wrote above, this is an important problem for us - what solution do you recommend ?
Oleg Terentiev
