8 years agoError(13264): Can't resolve multiple constant drivers for net "s_wr_data[71][239]"
hi,
when i compile following code,quartus reported a error—— "Error(13264): Can't resolve multiple constant drivers for net "s_wr_data[71][239]" " this problem puzzled me some time,how do i to sovle this problem? Thanks in advance and best regards! the code is as following:
parameter NUM_CE = 8;
parameter NUM_BLOCK = 80;
reg s_wr_data;
reg s_wr_en;
genvar i;
generate
for (i=0;i<NUM_CE;i=i+1)
begin:WR_CTRL
//write
always @( *)
begin
case(I_conv_mod)
4'd0:begin
if(loop_i==10'd0)begin
s_wr_data = s_wr_ofmap_data_c1;
s_wr_en = s_wr_ofmap_en_c1;
end
else if(loop_i==10'd1)begin
end
else if(loop_i==10'd2)begin
end
else if(loop_i==10'd3)begin
end
else if(loop_i==10'd4)begin
end
else if(loop_i==10'd5)begin
end
else begin
s_wr_en = s_wr_en;
end
end
4'd1:begin
if(loop4_3d==10'd0)begin
s_wr_en = {s_wr_ofmap_en2,s_wr_ofmap_en1,s_wr_ofmap_en0}; //0~7
s_wr_data = s_wr_ofmap_data0;
s_wr_data = s_wr_ofmap_data1;
s_wr_data = s_wr_ofmap_data2;
end
else if(loop4_3d==10'd1)begin
end
else if(loop4_3d==10'd2)begin
end
else begin
s_wr_en = s_wr_en;
end
end
4'd2,4'd3,4'd4,4'd5:begin
if(loop8_3d==10'd0)begin
s_wr_en = {s_wr_ofmap_en4,s_wr_ofmap_en3,s_wr_ofmap_en2,s_wr_ofmap_en1,s_wr_ofmap_en0}; //0~7
s_wr_data = s_wr_ofmap_data3;
s_wr_data = s_wr_ofmap_data4;
end
else if(loop8_3d==10'd1)begin
end
else begin
s_wr_en = s_wr_en;
end
end
default: begin
s_wr_en = s_wr_en;
end
endcase
end
end
endgenerate
1 Reply
I can only assume that some of the ranges for s_wr_data in the case statement overlap for different values of i.
each value of i in the generate loop produce parallel always blocks. And assigning the same bit in two always blocks will produce multiple drivers. You havent posted the declarations of the following: i_conv_mod, NUM_BLOCK_k5_LOOP, NUM_BLOCK_k3_LOOP
