16 years ago --- Quote Start --- The error seem to be in the UART since the uart rxd signal is Undefined (in red in modelsim) and txd value has always "1" so i suspect the program is not processed (simulated actually) or there's a communication problem (nios - uart) or even the architecture i've designed with SOPC is malfunctionning. I've used 3 IPs : the cpu nios, the onchi memory and the UART. --- Quote End --- I have the same problem. I was running the simulation for 800us and got an error: # 2281 ns: ERROR: cpu_test_bench/M_en is 'x' # Break in Module cpu_test_bench at ../cpu_test_bench.v line 572 I use Quartus 9.1 and NiosII EDS 9.1. I don't connect a hardware board to my computer. Any ideas?
