17 years agoIn SOPC Builder on the System Generation page there is a button "Run Simulator". When you click this Modelsim should open with the correct project and run a script which creates some shortcuts - a description of these should appear in the transcript window. You should then be able to compile the VHDL and memory contents each with one command.
