Debajyoti
5 years agoError While running AOCL with -simulator switch
Hi We are running simulation with OpenCL SDK . We used the -simulator option in-order to generated an .aocx file . We want to run and debug on Linux kernel in a simulation mode . We used Intel®...
BoonBengT_Altera
Moderator
5 years agoHi @Debajyoti,
Please do find the response below:
1) Unfortunately per my understanding, you can only perform a functional simulation in software for OpenCL kernels. For that you can refer to the Emulating and Debugging Your OpenCL Kernel steps here.
2) The -v command line is to generate the compilation progress, I dont think there is any connection with vsim logs, do let me know if I misunderstand the question.
3) Mind if I ask the error is related to ModelSim tool or from the design? Perhaps can check on the modelsim transcript log which usually located in the modelsim directory to see if any cause of the auto close can be identified.
Please do let us know if that helps to clarify.
Best Wishes
BB
