Error While running AOCL with -simulator switch
Thanks a lot for the reply . We are now able to checkout the vsim license connecting with AOCL after setting the correct $PATH
But , unfortunately , we are seeing that once the vsim simulation starts , the Modelsim GUI window exists automatically .
The modelsim GUI provides some error message , but we are not able to retrieve from some log files .
we are stuck now and need help .
We also , have the below queries related to running the Modelsim Project Files
1. Can we run Modelsim on the generated RTL files explicitly ? currently , we are using -simulator along with the .cl files to generate + simulate
2. We have used -v in the aocl command line to enable verbosity , but looks like vsim log files are not getting generated somehow . We also want to use vsim -l kind of inputs to generate the compile , simulate logs for further analysis
3. We don't want exit the VSIM GUI window if there is any ERROR occurred .
Above debug aids will be very helpful to analyze the issues further
Thanks a lot for the help
Deb
