Debajyoti
5 years agoError While running AOCL with -simulator switch
Hi We are running simulation with OpenCL SDK . We used the -simulator option in-order to generated an .aocx file . We want to run and debug on Linux kernel in a simulation mode . We used Intel®...
BoonBengT_Altera
Moderator
5 years agoHi @Debajyoti,
Thank you for posting in Intel community forum and hope all is well.
From the error it seems that the compiler are not able to locate ModelSim.
Mind if I ask do you have modelsim installed on your environment?
If yes please do check if the HLS configuration path is set correct for HLS
For environment variable to check you can refer to some path mention here.
Please do let us know if that helps.
Best Wishes
BB
