11 years agoError while debugging using system-console
Hi, I am trying to debug a design containing Nios II on a Stratix V FPGA. When debugging with system-console, while trying to do a memory read, i get the following error : % master_read_me...
11 years ago --- Quote Start --- Hi, I am trying to debug a design containing Nios II on a Stratix V FPGA. When debugging with system-console, while trying to do a memory read, i get the following error : % master_read_memory $nios 0x00000 4 error: master_read_memory: com.altera.systemconsole.internal.plugin.jtag.oci. Nios2DebugException: Target is broken and needs to be reset while executing The RAM in my design doesn´t seem to work. How can I solve this? --- Quote End --- Did you stop the NIOS operation before the command being executed? I guess it corrupts in the middle of NIOS firmware.
